Android Oyunu Caps Game v1.1.3 For Android
  • 37.960 Mesaj sayısı:
Gönderim tarihi: 08 / Şubat / 2012 / Çarşamba - 16:27
Screenshots:
REQUIRES ANDROID:
2.1 and up
Knock out opponent’s caps off the table. 54 levels, great graphics and physics
Take on the role of Caps Commander. Your mission is to exterminate enemy caps by throwing them out of table.
You have 3 battle caps available with whom you need to throw your enemy out of battlefield (table).
TABLES:
Missions takes place in 9 different areas, including office desk, watchmaker’s table, children’s table and kitchen table. On every table there are lying various objects which can block enemy attacks or just prevent your attacks. Under objects there are hidden bonus stars which can give you additional points.
At the beginning accuracy of your enemy is quite low but along with progress it raises and it becomes a real challenge.
HANDLING:
In every turn you move with all your caps one after another.
To shoot using cap just stretch it and release. Your cap should hit the opponent’s cap to throw him out of the table.
You can zoom in and zoom out by pinching the screen. To move the camera just touch the screen and move your finger. To center the view, just double tap anywhere on the table.
Download:
http://ul.to/2cz4fksl
http://www.mirrorcreator.com/files/3....1.1.zip_links
