Android Uygulama Launcher 7 - Donate v1.1.4
  • 37.956 Mesaj sayısı:
Gönderim tarihi: 08 / Şubat / 2012 / Çarşamba - 10:04
Requirements: Android 2.1+
Overview: A Windows Phone 7 style launcher for Android.
Unlike other current WP7 launchers (Windows Phone Android, Metro UI), this one allows you to properly modify
your start screen. Just long press on a tile and drag tile where you want!
Features:
- 1x1, 2x1 and 1x2 tiles with configurable colors
- Widgets in a tile! (provided that widget fits)
- Almost real like tile animation
- Almost real like tile re-arrange mode
- Almost real like status bar
- Animated contacts tile (supports G+ synced contacts)
- Pinnable contact-tile which animates like the real phone
- Folder tiles
- Webpage tiles
- Filterable application list
- Stock wp7-like colors and color selection
FAQ:
- Initial setup may be broken depending on your phone manufacturer, you probably need to replace the tiles
- To add new application to main screen, long press on an application in application drawer and select "pin
to home screen"
- Filtered apps can be restored from the launcher settings fitered apps page
- Tiles can be made transparent by adjusting the alpha value from the horizontal bar on the color selector
- All bitmaps must fit inside 48 megabyte heap (high-end phones, lower-end phones even less than that), so
don't try to use too many 25 megabyte bitmaps on your tiles or you will see FC.
- Gmail tile will not work anymore, use Mail tile instead
- By default WP7 statusbar shows icons only if you touch it. You can adjust the functionality from statusbar
options
- "Smaller tiles" will make 1x1 tile to 172x172 pixels in HDPI resolution. I managed to measure the tiles
wrong when I started developing L7 and tiles have been too big ever since.
-172x172 tiles seem to be faster too, so I suggest you to try them!
TODO-list:
- folder of contacts tile
- revamp the application icon addition (allow text color selection etc)
- App integration (Twitter, Facebook etc.)
- two-sided tiles
- cropping tool to make custom bitmap selection easier
-rotating tiles have made an epic return
-orientation lock on the first page will enable / disable real landscape mode, the rotating tiles is back in
-animation options and will have function ONLY and ONLY if you lock the orientation to portrait
-sluggish ICS scrolling fixed [really, this time I actually activated the APK]
-fixed issue where async loader no longer delivered new contact images to contact tiles
-fixed issue where multiple contact tiles wasted extra memory
Provided by: -Market Militia-
HTML Code:
http://www.mediafire.com/?a7kf1ncqt2r55ad
Mirror:
http://www.MegaShare.com/3894375
http://extabit.com/file/28y4ffrvxyke0
http://uploadmirrors.com/download/GB...t-Militia-.apk
