Traffic Monitor v3.1
Requirements: Android 2.2 and up
Overview: Data traffic monitor with integrated speed test and task manager.
Download and upload throughput as well as ping durations can be measured via an integrated speed test.
An integrated QoS (Quality of Service) module shows the connectivity as well as availability of data services.
The task manager displays running processes which can further be stopped upon request.
You may want to add the traffic monitor widget to your home screen. You can choose between a 4x1 and a 1x1 widget.
Data traffic counter
- Data traffic counter for wireless and mobile access, separated by up-and download.
- Tethering traffic, when device is used as mobile hotspot
- Traffic statistics per application
- Traffic statistics for current and last day as well as current and last month
- Configurable start day of monthly measurement period
Speedometer
- Measure speed and delay of your wireless connection
- History with your geo-located speed tests
Task manager
- Check currently running apps incl. memory usage
- Kill memory / traffic hungry apps
Quality of Service
- Check your network availability as well as the availability of data services
- Daily and monthly statistics
Furthermore, the app shows the following information (accessible via the options menu in the data traffic view):
- Battery status (level, voltage, temperature)
- Mobile network and cell information
The application is AD FREE. Please give us a COMMENT and RATE.
1. Quality of Service module: Check your network connectivity as well as the availability of data services.
2. Revised User Interface with tab bar at bottom.
3. Portugese language support - Muito Divertido!
http://depositfiles.com/files/ooieddhec
Mirror:
http://mir.cr/HK9M4ABA
Speedometer
Task manager
Quality of Service
Mirror:
