Blackberry Uygulaması Keygen Magic Icon 2.0.2
  • 37.939 Mesaj sayısı:
Gönderim tarihi: 04 / Şubat / 2012 / Cumartesi - 14:49
magicIcon - Change system and 3rd party application icon with any picture
Do you want to change the default icon of the application on your Blackberry without having to install a theme what else?
MagicIcon will help you with that, it allows to change icons of the applications available on RIM and 3rd party applications.
Change application icon is simple. Just select the application from the list and select a custom image. These images can be in any format jpg, png, gif support it as long as BB. Ideally, you should edit the image or your logo to fit the size of icons on the BlackBerry from the desktop and then save it to your SD card. For Storm and Tour format size is 73 x 73. If the image is larger than the size of the icon it will automatically be scaled down (but can be cracked) MagicIcon also work well with all themes Themes are not accompanied by RIM. And these changes will not be lost when reset BB. This is a list of RIM system software can change the icon:
BlackBerry Messager
Browser
Calendar
Calculator
Camera
Contacts
Clock
Global Search
Help
Maps
Memo
Options
Password Keeper
Setup Wizard
Task
Video Recorder
Voicenote Recorder
And most 3rd party software such as WordToGo, SlideShow ...
Operating System
4.7 Non-Touch, 4.7 Touch Screen, 5.0 Non-Touch, 5.0 Touch Screen, 6.0 Non-Touch, 6.0 Touch Screen
Download Here :http://www.mediafire.com/?1sf3ax8zn2xd09u
if someone have the serial for this verson ,,my pin : 21B38B14
