  • Facebook ile giriÅŸ yap Twitter ile giriÅŸ yap OpenID ile giriÅŸ yap Windows Live ile giriÅŸ yap Log In with Google      GiriÅŸ Yap
Android Uygulama WiFi File Explorer PRO v1.6.3
Gönderim tarihi: 03 / Şubat / 2012 / Cuma - 07:54
REQUIRES ANDROID: 1.6 and up
Overview: Browse, download, upload, delete, copy, ZIP, stream and manage files via WiFi!!
* Featured on Life Hacker, PC World & Android Central and recommended by Motorola! The ORIGINAL, best, steadiest and most popular WiFi file transfer app with now over 1 million users across all app stores worldwide! *
Browse, transfer, download, upload, delete, copy, rename, stream and manage files that are on your Android device, using a web browser via a WiFi connection.
No more taking your phone apart to get the SD card out or grabbing your cable to access your camera pictures and copy across your favourite MP3s.
"I wholeheartedly recommend going the wireless route with WiFi File Explorer!" - PC World review - 5 stars.
"Best couple of bucks I ever spent." - Top app of 2011 - from Android Central's Jerry Hildenbrand.
FEATURES
1. Using a web browser, you can browse and download all the files on your Android device without the need for a cable. Download entire directories with one click which no other similar app offers;
2. Multiple batch file uploads and downloads to save you time when transferring many files at once from your computer to your Android device or vice-versa;
3. Backup your entire SD card or just backup individual directories with one simple click – for example, backup all your photos just by downloading the Camera directory!
4. Download a streaming media playlist to allow you to quickly flick through and stream all the stored media files in a directory into a media player on your computer. This is a unique feature not offered by other apps;
5. Create brand new directories and delete/rename/copy/zip/unzip files - the perfect file manager;
6. Use the one of a kind gallery viewer to create a slide show of all your camera pictures directly from your Android device. Simply click on a picture’s file name to launch the gallery viewer and then hit the play button to enjoy all your pictures in the web browser;
7. Search box so that you can find any file on your Android device;
8. Select between thumbnail and detail views to choose the best method to quickly browse your files. Thumbnails are supported for both pictures AND videos!
9. It is also uniquely an installer, so automatically install app files with just once click in the web browser;
10. With with one simple click you can set any audio file on your device to become your ringtone;
11. View all the camera pictures and videos or listen to all the music on your Android device streamed directly in a web browser. Use shortcut tabs to quickly view ‘All Music’, ‘All Pictures’ and ‘All Videos’ stored on your device, no matter which directory they are in;
12. Runs as a service in the background so you can use other apps while you are making transfers;
13. Simple to use with no set up or buttons – it just works!
14. Password protected to prevent unwanted access;
15. Ability to configure the port settings;
16. Full support for special characters in file names which competitor apps do not support;
17. Visual indicators and stats of how much free space is on your Android device as well as real-time indicators of how much battery and WiFi signal you currently have;
18. Send an email to the web link from the app for easy connection;
19. Special “Development Goodies” mode to enable SSL protection – email developer for details!
20. LOTS more features in development;
If you do have problems using this application on your WiFi network, it is most likely a configuration problem with your router/network. Please contact the developer if you have any questions and he may be able to help you ... but please don't rate low because your network isn't configured properly - that isn't the application’s fault ;)
  1. Explicitly don't require a touch screen so app can support Google TV devices.
Download Link: 1022.23KB
http://www.mediafire.com/?yy71khdywt1ii9y
http://mir.cr/LNJ4VY92
http://www.embedupload.com/?d=1SYZMXCGGS
http://uploadmirrors.com/download/1U...PRO_v1.6.3.apk
