Android Uygulama RocketDial Pro v2.8.23
  • 37.912 Mesaj sayısı:
Gönderim tarihi: 03 / Şubat / 2012 / Cuma - 10:01
REQUIRES ANDROID: 2.0 and up
Overview: Best dialer and contacts management tool you can have !
Ready For Android 4.0 (ICS) !!!
Detailed Features:
- Fast and Powerful Smart search T9, search for names, organizations, title, phone numbers,websites, notes... and all the information contacts have, change the search easily by long click the "#" button.
- Fast search from History, Search by name or by phone number !
- Favorites support, large buttons for select, quick and easy dialing.
- Support facebook accounts , show photo from facebook. (before 4.0)
- Perfect contacts support : operate on single or multiple contacts , send messages, write emails, delete your contacts in one click, everything is fast and convenient.
- Speed dialing numbers 1 - 99, press and hold the button to assign a speed dial. You can also configure the speed dial menu.
- Call Confirm, show confirmation dialog every time user placed a call, no more accidental calls.
- Perfect T9 search for groups , easily find the group through T9 search group name. support adding color for each groups tab.
- Set Group Ringtone, group message, group email, group black list.
- Advanced call history management, batch mode, quickly create a reminder in your calendar for the contacts and so on.
- Search Contacts simply through finger-drawings
- Perfect support for Last name first display method, support contacts order on last name.
- Supports UK/China/US/Canada Area Code, show locations for incoming/outgoing calls.
- Change background , choose picture from your phone to use as dialer background.
- Caller ID for incoming calls, supports full screen contact photo , supported features: answer, endcall, callback,enable speaker and answer , send sms back and decline, silent
- Call End that can exit dialer and lock screen directly (android 2.2 and above) when you finish a call
- Vibrate on phone connected.
- Vibrate on Phone end.
- Beep on Phone End
- Manage Contacts account by account
- Duplicate Contacts from account to account.
- Black List, support reject incoming calls from your black list.
- Format phone numbers , support location US/Canana/UK/Russia/Ukraine/China/Taiwan
- Show organization of contact when calling out or receiving the calls.
- Use finger drawing to search the contact, easy to use in car .
- And many other exciting improvements .
- Configure Alphabet Bar on your own , show alphabet bar in your language.
- Gesture Navigation, write the character to navigate to contacts.
- Support landscape mode.
Below Character Sets are supported:
Russian, English, German, Hebrew, Greek, Georgian, Ukraine, French, Hungarian ,Polish ,Swedish, Arabic, Persian, Portuguese and most of the Latin characters, also Simplified Chinese, Traditional Chinese
Note:
If you enable Lock Screen Feature under android 2.2. You have to uncheck the "Setting-->Location and Security-->Select Device Manager--> RocketDial" in order to uninstall RocketDial
  1. New: Some small adjustments for default UI.
  2. New: Configurable Font size for Caller ID .
  3. New: Configurable Font size for Call History.
  4. New: Improved Favorites Loading performance.
  5. New: Added More Contact Info when sending contact.
Download Link: 2.98MB
http://www.mediafire.com/?edhncyvjnw17o4k
Mirrors
Mirrors
Mirrors
