Android Uygulama Transparent Screen Pro v1.11
Gönderim tarihi: 29 / Ocak / 2012 / Pazar - 23:45
REQUIRES ANDROID: 2.2 and up
Overview: This app gives you the opportunity to use your phone as usual, while being able to see the image of your camera transparently on the entire screen.
You want to use your phone while you're walking and still see what's going on in front of you? Make your screen transparent!
Pro features:
- No Ads (the internet permission is not anymore needed)
- "start on application startup" option
- "stop if display goes off" option
If you encounter any problems or you think a feature is missing, simply send me an E-Mail. I take care of all requests as quick as possible.
FAQ:
- Why is the App requesting the permission "DISPLAY SYSTEM-LEVEL ALERTS"?
This permission allows me to show the image of the camera, while you're able to use the phone as usual.
- Does it effect the battery draining?
Yes, it needs some more resources. But I'm trying to keep it as low as I'm able to ;)
- Why is it a bit laggy?
I'm not able to prevent that! It's due to the use of transparency. But it is stable enough on most phones and lowest resolution, to do what it's intended to do.
- Does my phone need to be rooted?
NO!
Release of the Pro version (check the free versions changelist for details)
Download Link: 85.24KB
http://www.mediafire.com/?8orh8lralexqscg
http://mir.cr/R7AQ9RME
http://www.embedupload.com/?d=0AKJABVCNG
