Android Uygulama VLC Direct Pro v7.6
Gönderim tarihi: 30 / Ocak / 2012 / Pazartesi - 02:21
VLC Direct Pro v7.6
REQUIRES ANDROID: 2.0 and up
Overview: No more file transfers! Stream and play Music and Videos anywhere you want!
PROMOTIONAL PRICE FOR A LIMITED TIME!
Do you like to watch videos or listen to music? Then this application is for you.
No more file transfers! One click and you will be streaming videos, music and photos from your computer to your Android and from your Android to your Computer.
No Ads! No time Limits!
You can also control your VLC Player from your phone or tablet: browse files, play, enqueue, pause, stop, volume, fullscreen and more.
This is the only application of the entire market that can stream videos and music in both ways:
* From Computer to Android
* From Android to Computer
With this application you can play music, videos and photos in your computer's VLC or in your Android device. You don't have to worry where your files are stored -they can be in your android or in your computer-, VLC Direct Pro will take care of streaming when necessary.
NEW FEATURE: SUBTITLES SUPPORT! (.srt files)
* SUPER EASY CONFIGURATION - JUST ONE CLICK AND YOU WILL BE READY TO GO!
** Even when VLC Direct Pro supports streaming through 3G/4G. It will depend on the 3G/4G carrier. Take into account that many carriers block RTSP packets. **
* Only for advanced users: If you want to use VLC Direct Pro through remote networks these are the ports you will have to map in the routers:
* 8080 (VLC Web Interface)
* 4444 (Streaming from Android to VLC)
* 5554 (Streaming from VLC to Android)
NOTE TO VLC DIRECT FANS!
Thanks a lot for your support and for the nice reviews!
I listen to you and I am working on adding features you are missing.
Reviewing the app helps a lot, so thanks for the feedback and supporting VLC Direct!
Important: If you have any problem using VLC Direct, please don't post a comment in the market because I won't be able to get in touch with you: Google doesn't share user emails with developers; Just send me an email to qdevplus at gmail.com or post in VLC Direct blog. I will be glad to help you.
  1. Bugfixes
  2. Performance Improvements
Download Link: 883.85KB
http://www.mediafire.com/?224naon0segtj67
http://mir.cr/N50V0SFF
http://www.embedupload.com/?d=2XFWZJIUYX
