360 Launcher v1.5.1 (+ themes, lockscreens)
Requirements: Android 1.6+
Overview: This is a combination of QQ Launcher and MXHome. It has a lot of features such as some free downloadable theme, animation, etc. If you love ADW, you will love it even much.
screenshot-1326984124266.jpgscreenshot-1326984194355.jpgscreenshot-1326984204372.jpgscreenshot-1326984217099.jpgscreenshot-1326984224842.jpgscreenshot-1326984244016.jpg
About the launcher:
360 Launcher:
Clean
Fast
Extremely Smooth <<< You won't find another launcher which is as smooth as this. Don't trust me? Try it out!
Extremely Clear
Beautiful
Just Amazing
This is a combination of QQ Launcher and MXHome. It has a lot of features such as some free downloadable theme, animation, etc. If you love ADW, you will love it even much. Want to know more about it? Head to this site.
Features:
(based on Beta 1.3)
Download theme from its site
Download custom lockscreen from its site
Download wallpaper from its site
Quick launcher widget (power widget)
Built in clock widget
Built in power saving widget (more setting requires 360 Battery Guard)
Folder in Home screen
Folder in Launcher
Unlimited apps in a Folder
Built in lockscreen
Built quick system setting widget
Icon transition animation in Home screen
Icon transition animation in App Drawer
Hide application
Built in lockscreen with theme
Drawer and charts has iPhone remove jitter effect
Icon background
Transition animation in app drawer
Transition animation in home screen
Launcher has tab to Apps, Music, Pictures and Video.
Custom app in dockbar
etc
Changelog
BETA 1.0
Launcher 360 Initial release - 14th November 2011
-Everything works except weather
Launcher 360 update 1 - 15th November 2011
-fixed a extra chinese word
(Weather is still not fixed yet as it is still in beta stages.)
Launcher 360 Beta 1.0 Update 1 with Samsung TouchWiz heme moded by yken available here
BETA 1.1
Launcher 360 - 22th November 2011
-It has it's own lockscreen! 1345601
(NOTE: MAY NOT WORK! Make sure you set 360 Launcher as the default launcher to get this work.
-Icon backgrounds can be added.
-New weather widget (Not recommended to use it as the time is really overlap each other. It will not overlap in Chinese as the word is short)
-Unlimited app in a folder
-Power saving widget is added (more profile required 360 Battery Guards (Translated).)
-Actually new weather has a lot more features. e.g. Chinese festival, lunar calendar etc. unfortunately, after being translated, every text including date is over lapped
-Weather is still not fixed yet.
-etc.
Launcher 360 Update 1 - 23th November 2011
-Clock widget is fixed (removed those unwanted words).
-Weather widget word is removed (it will show only the green picture).
-Switches Align in switches in Home screen is fixed.
-Icon Background has been changed to Icon BG due to insufficient space.
-Translated those 2 pictures I missed
BETA 1.1.1
Launcher 360 - 5th December 2011
-Drawer supports iPhone remove jitter effect.
-Flashlight widget will enable LED light.
-Repaired lock-screen (beta version) to unlock the problem in some models.
Launcher 360 Update 1 - 5th December 2011
-Add missing translation image.
-Change those words in menu so that it wont show "aaaa aaaa..." (the dot).
-Weather is still not fixed yet (suggestion already given to the development team)
NOTE: Weather only work in China area, it won't work outsite China. I've deleted the "weather not found" in the green box so it won't keep showing annoying words.
BETA 1.2
Launcher 360 - 14th December 2011
-Added lockscreen online download.
-Added more online wallpaper.
-Added English language. (Added translated introductory pictures)
-One key RAM free is fixed
-Large resolution is supported
BETA 1.3
Launcher 360 - 30th December 2011 - Removed from the attachment list due to too many bug.
-Added in my own English version as they forgot to patch that in.
-Lag in app drawer is fixed
-Added Apps, Music, Video, Pictures tab in app drawer for faster access
-Almost every bug is fixed.
-List view in app drawer.
-Difference sorting view in app drawer is added.
-Option to take screenshot in Launcher.
-Custom app in dockbar.
-One click cleaner that kill data is fixed.
NOTE: If your built in gallery fc's and you are on Android 4.0, disable 2d graphics rendering in developers option. If you're on gingerbread you probably need to do a complete wipe, reinstall your ROM and the 360 launcher. (It's not the launcher that is fc-ing, it's probably the gallery of the ROM which has trouble with 360.) Thanks Eeuwe for providing tips!
BETA 1.3 Update 1
Launcher 360 - 31st December 2011 (Version provided by 360 Product Manager, unable to find it from 360 Forum or Market. Only available in XDA)
-Fix bugs.
-Enhanced UI.
NOTE: Launcher may lag for the first time.
BETA 1.5
Launcher 360 - 17th January 2012 - Removed as blurry icon image is fixed in Beta 1.5.1
-New UI.
-Huge icons.
-Folder can be hide in image tab.
-Enhance UI.
-Smaller installer file.
-Optimize for speed.
BETA 1.5.1
Launcher 360 - 18th January 2012
-Enhanced icon.
BETA 1.5.1
Download Link: http://flashmirrors.com/files/0nx2ab..._Beta1.5.1.apk
Lockscreen+Themes
Download Links:http://www.mirrorcreator.com/files/L...es_0.rar_links
Launcher 360 Lockscreens&Themes.rar
About the launcher:
360 Launcher:
Clean
Fast
Extremely Clear
Beautiful
Just Amazing
Features:
(based on Beta 1.3)
Folder in Launcher
Built in lockscreen
Hide application
Icon background
etc
Changelog
BETA 1.0
BETA 1.1
-etc.
BETA 1.1.1
BETA 1.2
BETA 1.3
BETA 1.3 Update 1
-Fix bugs.
-Enhanced UI.
BETA 1.5
-New UI.
-Huge icons.
-Enhance UI.
BETA 1.5.1
-Enhanced icon.
BETA 1.5.1
Lockscreen+Themes
