Android Tema Spectrum ICS Pro LWP v1.0.8
Gönderim tarihi: 26 / Ocak / 2012 / Perşembe - 22:43
Requirements: Android 2.1 and up
Overview: Great for new Android 4.0 Ice Cream Sandwich themes with floating particles.
Spectrum live wallpaper, beautiful abstract colors with floating particles.
Also great for new Android 4.0 Ice Cream Sandwich themes.
Great for new Android 4.0 Ice Cream Sandwich ICS themes with floating particles.
Spectrum ICS live wallpaper, beautiful abstract colors with floating particles.
Features
- Beautiful abstract colors
- Setting widget
- Custom background color
- 5 background themes
- 2 shadow types
- Strip settings
- Dust settings
- Light element settings
- Parallax effect
- Use 3D hardware to render images, save battery
- Support most resolutions including Android 3.0 tablet
Instruction
Home -> Menu -> Wallpapers -> Live Wallpapers
Note: It is live wallpaper so you can't open the app, you will need to follow the instruction above in order to set the wallpaper. Also slower/older devices (shipped with Android OS below 2.1) can't run it too, currently it has been tested on Nexus S, HTC Desire and Samsung tab so any mobile devices that is equivalent to them should run fine.
If you have put the app on SD card and restarted the phone, the wallpaper will reset to default since the system couldn't find the app first.
Download
