Requirements: Android OS 1.5+
Overview: Complete battery monitoring with notification icon, history, graphics and alarms
Special offer! Get it while it lasts!
Lowest consumption battery monitor and widget showing capactity, charge/discharge (mA & mW), voltage, temperature and remaining time.
Shows %, temperature and mA in status bar using external packages.
Shows and saves history, shows scrollable/zoomable graphics, long-press for full-screen.
Triggers alarm based on battery full/charged or voltage and temperature levels.
To get battery % in status bar, go to settings, notification and alarms then select icon type 'external package'.
Lowest battery consumption on the market!
If you want only the notification icons/alarms, you can disable the graphics and history to reduce consumption even more!
Wide widget can display any data, check settings.
Recommended by Motorola support team!
Not all phones supported:
- mA data may be desynchronized and/or estimated
- Some data may not be reported at all
Support for Motorola Defy and Atrix 1% reporting can be activated from Settings/Monitoring.
TODOs:
History browsing and/or backup/restore
Provide data to Process Monitor Widget
Traditional Chinese translation
Video tutorial!
NB: If you have a problem please email-me, bad comments won't help you or anyone else!
KW: battery widget current voltage temperature battery monitor power drain charge discharge graphic mA capacity multi function graph prediction estimation time
http://www.mirrorcreator.com/files/1...b206.apk_links
TODOs:
Video tutorial!
- 2.0.6:
- Charger output power now optional
- New option to hide or remove label
- 2.0.5-1.9.5:
- New ICS and transparent glass widget themes
- Improve mAh estimates using charger output power
- New automatic mA refresh rate
- New history markers with drain information (pro only)
- New zoom visible duration
- New multi-battery comparison screen
- New Russian translation (thanks to Dmitry Chornenky)
- New Polish translation (thanks to Lukasz)
- Update Italian translation (thanks Roberto)
