  • Facebook ile giriÅŸ yap Twitter ile giriÅŸ yap OpenID ile giriÅŸ yap Windows Live ile giriÅŸ yap Log In with Google      GiriÅŸ Yap
Android Uygulama EZ Cam Widget v1.08
Gönderim tarihi: 25 / Ocak / 2012 / Çarşamba - 01:20
EZ Cam Widget v1.08
REQUIRES ANDROID: 2.2 and up
Overview: EZ Cam Widget makes snapping a photo or capturing a video quicker and easier than ever before.
The easy-to-use widget can be added to your main home screen, allowing you to take a photo or begin recording a video mere seconds from getting it out of your pocket. A variety of settings can be configured after installation meaning the camera will always be ready to snap a picture just the way you want it.
The features include:
- Easy to use camera widget with buttons to capture an image, begin recording a video and a link to the main application.
- Choose from your camera's supported flash modes.
- Choose from your camera's supported photograph resolutions.
- Choose from your camera's supported focus modes.
- Ability to disable auto focus for a speed shot, or enable it for better quality images.
- Choose from your camera's supported scene modes.
- Choose from your camera's supported photograph effects.
- Choose from your camera's supported white balance settings.
- Enable video resolution override for certain devices where the automatic video settings are incorrect. * (See note below)
- Toggle video flash on/off
How to Install:
1. To display the widget on your homescreen, enter the menu and select Add or Personalize. Alternatively touch the screen and hold it until the menu appears.
2. Navigate to Widgets » EZ Cam Widget and it should now be displayed on your current homescreen.
3. Start the EZ Cam Widget application from your Applications menu or from the button on the widget and navigate to the Settings tab. Change the camera settings to suit your needs.
4. Tap the photo button on the widget to instantly take a snapshot, or use the video button to begin recording.
5. The saved videos and photos can be found in the 'EZ Cam Images' and 'EZ Cam Videos' folders on your SD card and are viewable in your gallery.
* Note: EZ Cam Widget automatically detects the devices highest video settings, however the method provided by Android to do this has proved slightly unreliable on certain devices. A few devices used while testing the application showed this problem, these were the Samsung Galaxy S2, HTC Desire HD and HTC Desire S. With all of these devices the override resolution option needs to be used to set a supported recording resolution (see the known issues section below).
Please be aware that the camera hardware is different for almost every device, this makes it difficult to create an application that is compatible with every Android phone. If you have any problems with the application please email us with a detailed explanation of your problem and the Android device you are using. We take any problems with our applications very seriously and will help you solve your problem as soon as possible.
Known Issues:
A few devices have known issues and can be solved by using the manual resolution override option. Here is a list of known fixes:
- HTC Desire S - Ensure a supported video resolution is selected and the manual resolution override option is enabled.
- HTC Desire HD - Video will work but will record at lower resolution, this can be set to 1280 x 720 manually.
- Samsung Galaxy S2 - Problem with recording video at high resolutions, ensure manual resolution is set (max. 720 x 480).
  1. Known issues added to application home.
  2. Certain non applicable settings removed from lists (e.g. face detection focus mode).
  3. Video mode set to landscape view rather than portrait.
  4. Email link added to about page.
  5. Licensing added.
  6. Bug Fixes.
Download Link: 266.48KB
http://www.mediafire.com/?1zz1i2m47bqqji7
http://mir.cr/I6AG1V7B
http://www.embedupload.com/?d=4QDJOXMQLW
