Android Uygulama Launcher 7 - Donate v1.1.1
  • 37.912 Mesaj sayısı:
Gönderim tarihi: 24 / Ocak / 2012 / Salı - 00:58
REQUIRES ANDROID: 2.1 and up
Overview: The Winphone 7 lookalike launcher, almost like the real thing and in some ways even better!
Ad-free version of Launcher 7.
Version 1.0.1.24 notification: if you find rendering error, email me with screenshot and I will try to fix the issue ASAP.
Features:
- 1x1, 2x1 and 1x2 tiles with configurable colors
- Widgets in a tile! (provided that widget fits)
- Almost real like tile animation
- Almost real like tile re-arrange mode
- Almost real like status bar
- Animated contacts tile (supports G+ synced contacts)
- Pinnable contact-tile which animates like the real phone
- Folder tiles
- Webpage tiles
- Filterable application list
- Stock wp7-like colors and color selection
FAQ:
- Initial setup may be broken depending on your phone manufacturer, you probably need to replace the tiles
- To add new application to main screen, long press on an application in application drawer and select "pin to home screen"
- Filtered apps can be restored from the launcher settings fitered apps page
- Tiles can be made transparent by adjusting the alpha value from the horizontal bar on the color selector
- All bitmaps must fit inside 48 megabyte heap (high-end phones, lower-end phones even less than that), so don't try to use too many 25 megabyte bitmaps on your tiles or you will see FC.
- Gmail tile will not work anymore, use Mail tile instead
- By default WP7 statusbar shows icons only if you touch it. You can adjust the functionality from statusbar options
- "Smaller tiles" will make 1x1 tile to 172x172 pixels in HDPI resolution. I managed to measure the tiles wrong when I started developing L7 and tiles have been too big ever since. 172x172 tiles seem to be faster too, so I suggest you to try them!
TODO-list:
- folder of contacts tile
- revamp the application icon addition (allow text color selection etc)
- App integration (Twitter, Facebook etc.)
- two-sided tiles
- cropping tool to make custom bitmap selection easier
  1. landscape mode added, landscape mode has its own set of tiles
  2. rotating tiles are gone
  3. new initial configuration, should popup if homescreen is empty, but can be accessed from settings too
  4. and lots of other adjustments
Download Link: 2.02MB
http://www.mediafire.com/?p5smmumg7d7odsu
http://mir.cr/TFHZ3X58
