Blackberry Uygulaması Winhex Battery Watchdog v3.11.1
  • 37.912 Mesaj sayısı:
Gönderim tarihi: 22 / Ocak / 2012 / Pazar - 21:54
Requires OS 5 or higher
If you spend time monitoring your battery then you need this app. Battery Watchdog will do it for you. Battery Watchdog monitors your battery level and will send email/text/sound alerts and display dynamic icons showing current battery %. There is also a system-side menu showing the battery % and a way to jump to the app to change options. We encourage your comments and are looking for users experience to add new features.
More info
OFFLINE LINK
