Android Tema Solar System 3D Pro v1.31
  • 37.883 Mesaj sayısı:
Gönderim tarihi: 17 / Ocak / 2012 / Salı - 02:54
Requirements: Android OS 2.1+
Overview: The Solar System in 3D as animated Live Wallpaper
Animated Live 3D Wallpaper showing realistic views of the Sun, planets, asteroids, and moons of our Solar System with a starry background. Watch the Sun evolve towards a Red Giant (dependent on the battery status), use the orientation sensors to look around, enjoy splendid views at Saturn's rings, or fly through the Solar System.
Due to the realistic graphics, this is a very memory hungry wallpaper. Before buying, please keep in mind that it might not work on weaker devices.
This wallpaper provides the following features:
- Select any planet in our Solar System
- Watch asteroids zipping by
- Make the Sun evolve to a Red Giant as the battery becomes weaker
- Look around by sliding with the finger over the display or by using the orientation sensors
- Automatic camera movement (speed can be set)
- Move from the inner to the outer planets as the battery becomes weaker
- Change planet or acivate the orientation sensors through double-tap on screen
- Real star background from Milky Way panorama
(Note: For artistic reasons, the objects in the screensaver are not to scale. Also, not all moons are included.)
Activate this wallpaper by pressing the "Menu" button and selecting "Wallpaper" and then "Live wallpapers".
Version 1.31:
Bug removal: Asteroids are displayed now
Additional planetary nebula image
HTML Code:
http://www.filesonic.com/file/FFtcLmo
Mirror:
http://ul.to/e63woxgf
http://www.multiupload.com/P4MQ5X6P4I
