Android GPS Navigasyon Uygulaması Ultra GPS Logger v3.130 [Patched]
#1 siirlerefendisi
    Administrator
  • 9.282 Mesaj sayısı:
  • YerKonya
Gönderim tarihi: 29 / Aralık / 2016 / Perşembe - 01:49
Requirements: 2.3+
Overview: Ultra GPS Logger is a GPS Tracker which allows you to generate NMEA, KML and/or GPX logs with your GPS or GLONASS enabled Android device. It is able to keep GPS on during standby, which enables logging of a long period of time without the need of interaction with the device.
- formats: NMEA, KML, GPX, CSV
- log raw, by distance or time
- log during standby
- AutoLog, AutoStart
- Send log / track by email
- Publish to FTP
- Compress log: Zip, KMZ
- Google Maps, Open Street Map
- POIs, etc
- Online Services
- Dropbox, OneDrive, Google Drive
- Barometer / pressure sensor
- use of internal GPS
- use of external GPS via Bluetooth
- allow other apps to use external GPS via Mock provider
- act as GPS mouse
Ultra GPS Logger logs raw NMEA sentences! This is much more accurate than other products which just log every minute... It also supports intelligent KML/GPX output, which logs only real movement. Ultra GPS Logger also lets your device vibrate and flash its led in case the GPS fix is lost. Furthermore it represents your track on Google Map or Open Street Map!
User feedback is highly appreciated. Ultra GPS Logger is used for a variety of activities, like hiking, sailing, car / motorcycle / yacht racing or geotagging. Let me know what you use Ultra GPS Logger for :)))
Quick Start Guide: Secured URL
User Guide (PDF): Secured URL
WHAT'S NEW
- map on main screen
- trigger/filter by category
- color by category
- colors for map polygons
- nmea extension
- more long press options on map:
- Mark POI
- Get Address
- Get Weather
- Kalman filter option
- POI import improved
- POI based on address
- Overlay line and box
- new log format CSV
- multi settings backup
- treatment of KitKat storage restrictions
- option to deactivate example POIs
- pressure data retrieval fix
- new altitude compensation
- track playback
- some fixes / cleanup
This app has no advertisements
<p style="margin: 5px; font-family: Arial; font-size: 12px; color: #707070; text-align: center;">https://play.google.com/store/apps/d...tra.gps.logger
Download Instructions: No LP or GPM needed | Analytics Disabled | Maps work
Secured URL
Secured URL
Secured URL
Secured URL
2 Kullanıcı bu konuyu okuyor
0 üye, 2 ziyaretçi, 0 gizli üye
