Android GPS Navigasyon Uygulaması Fake GPS v4.7.7 [Pro]
#1 siirlerefendisi
    Administrator
  • 9.282 Mesaj sayısı:
  • YerKonya
Gönderim tarihi: 29 / Aralık / 2016 / Perşembe - 15:38
Requirements: 2.3+
Overview: Set your phone location to anywhere in the world with just one click, if you need to test other apps ability to track gps information without the need to catch a gps signal then this app is for you.
The following is needed to make sure the app runs smoothly:
1 - It is needed that you turn on "Allow Mock Locations" on Development Settings
2 - Dont forget to disable "Use wireless networks" options in Location settings in order to avoid an problem where you will keep receiving fake locations even after stopping Fake GPS.
3. Make sure you run Fake GPS first before running your app.
To help development you can use the following commands from the command line:
adb shell am startservice -a com.blogspot.newapphorizons.fakegps.START -e latitude 11.11 -e longitude 32.21
adb shell am startservice -a com.blogspot.newapphorizons.fakegps.UPDATE -e "latitude" 1.11 -e "longitude" 0.21
adb shell am startservice -a com.blogspot.newapphorizons.fakegps.STOP
WHAT'S NEW
Fix a crash on some devices
This app has no advertisements
<p style="margin: 5px; font-family: Arial; font-size: 12px; color: #707070; text-align: center;">https://play.google.com/store/apps/d...rizons.fakegps
Download Instructions:PRO features Unlocked | Map work | Analytics disabled
Secured URL
Secured URL
Secured URL
2 Kullanıcı bu konuyu okuyor
0 üye, 2 ziyaretçi, 0 gizli üye
