Android GPS Navigasyon Uygulaması Easy Speedometer Pro v1.90
#1 siirlerefendisi
    Administrator
  • 9.282 Mesaj sayısı:
  • YerKonya
Gönderim tarihi: 23 / Aralık / 2016 / Cuma - 02:42
Requirements: 3.2+
Overview: Use this GPS speedometer with altitude, geo-location, bearing and current time, especially when you are not driving a car but going by bicycle, by train, by boat or even by airplane.
Posted Image
With "HUD" (head up display) turned on you can put your device in front of mirroring glass (of an vehicle) to read the reflected displays.
You can quickly display the current geo-location without the need of an internet connection.
Simple displays but many possible options.
Features:
* Speedometer (km/h, mph, kn, m/s), digital and analog
* Analog meter with auto-range that adjusts to the speed, even at very high speeds
* Shows reached maximum speed and average speed
* Personal speed limit alarms (visual AND SOUND)
* HUD ("Head-Up-Display") to reflect and read the display in a window
* Odometer (km, mi, nm, m), 2 counters for current trip and total distance
* Altitude above sea level (m, ft)
* Geo-location (GPS-coordinates in degrees, minutes, seconds)
* accuracy of GPS-signal
* local time
* color change as warning on poor GPS signal
* all components can be turned on separately
* large numbers, depending on number of selected components
* different layouts (skins)
* receive and use collected values such as distance, max and average speed from the basic version of this app ("Kwd Tacho") - Make sure to have the latest update of both apps (version 1.81 or above).
Your device needs a GPS sensor to run this app.
An internet connection is NOT required.
If you are using Android 6.0 or higher you will be asked at app start for the location permission (and not on install). In case you are not asked you may have not allowed location access before. Then you have to go to the app settings of your device and enable the permission under the entry of "Easy Speedo Pro" again.
Have fun with this GPS-tool!
What's New
Bugs fixed, performance improved.
Direction blinks if it cannot be determined correctly at very low speed.
The altitude ASL is now more accurate.
The app shows a notification in the status bar if it is active in the background.
You can choose between decimal and degree units for location.
You can display a pointer like a compass needle.
This app has no advertisements
<p style="margin: 5px; font-family: Arial; font-size: 12px; color: #707070; text-align: center;">https://play.google.com/store/apps/d...peedopro&hl=en
Secured URL
Mirror:
Secured URL
Secured URL
Secured URL
