Android Uygulama SmartStay Ex Pro v1.3.5
Gönderim tarihi: 23 / Kasım / 2012 / Cuma - 23:14
EyeSpy keeps your screen from turning off while you are using it.
EyeSpy scans the front camera for faces at regular intervals. If a face is found, it will keep the screen from turning off. There are many advanced options available and many more planned!
PRO APP REQUIRES FREE APP TO WORK
PLEASE INSTALL THE "EyeSpy Test App" BEFORE BUYING EYESPY TO SEE IF YOUR DEVICE IS COMPATIBLE!
Features:
  • Supports Android 2.3+
  • Customizable check frequency
  • Optional status bar notifications
  • Optional customizable vibration notifications
  • Continuous mode (scan for a few seconds rather than taking a single picture)
What's in this version :(Updated : Nov 23, 2012)
  • [Feature] User guiden
  • [Feature] Support email buttonn
  • [Feature] Night scene (exposure compensation)n
  • [Fix] Various fixes
Required Android O/S :2.3+
play
Download
http://ul.to/ocorct9e
Mirror
http://www.filedownloads.org/ttkk4oi...dshgf.rar.html
