Android Uygulama Clean Master (Cleaner) v2.1
Gönderim tarihi: 23 / Kasım / 2012 / Cuma - 06:46
Requirements: Android 1.6+
Overview: Clean Master is a Must Have cleaner app for android users. It provides comprehensive cleaning methods to clean cache, unused files, privacy history and app packages on android phones. It also kills running tasks and releases RAM to boost your phone and save battery life.
What is Clean Master?
Why choose Clean Master?
Clean Master is easy and effective. After a comprehensive cleaning, MBs even GBs space will be released for your phone. No superuser permission required.
[What is Application Cache Files]
Application Cache Files are the temporary files created by applications. For example, while you're using browser, it saves the images as cache files. It's the same for other application and all you need is a rated cache cleaner. Using Clean Master to clear cache files regularly will save phone space and speed up application reaction.
[What is Unused Files]
After installing an app from market, it's sometimes required to download extra data. However, when you uninstall that app, the data is still there, which makes your available space smaller and smaller. For example, almost all the games from Gameloft require a huge extra data, from 200M to 1GB. But the data would be there even the game uninstalled. Clean Master will save GBs for your phone, after cleaning these unused files.
[What is Privacy History]
Privacy History is including the history of web browser, Google Play store, Google Maps, Gmail and clipboard. If you don't want others to know what you were doing, and searching around, Clean Master is definitely the one you need to protect your privacy.
[What is App Packages]
App Packages are the .apk files used to install apps. When you download and install apps from markets, updating them on phone, the app packages are becoming more and more, eating the huge space of your phone. However, you should no longer worry about this issue, because Clean Master can find all the app packages on your phone, and clean them for you by an easy tap.
[What is Task Killer]
The tasks running on background not only occupy system RAM, but also waste your battery life. The new Task Killer arrived on Clean Master. It
can kill the unwanted tasks and release more RAM to speed up your android phone. An excellent shortcut is also provided to make the work cannot be easier. Root permission is not necessary, but if Task Killer granted root permission, it will perform better.
PS: The important system tasks have been whitelisted already, if you notice any problems while using Task Killer, please contact us.
Key Features:
Clean cache Files
Clean unused files
Clean privacy history
Manage and clean app packages
Remind unused files when app installed
Kill running tasks/release RAM
1. Cache cleaner UI adjustment.
2. New algorithm released to detect and clean app cache.
3. Other bugfixes.
play
Download
http://www.filedownloads.org/ilm0wsm...aster.rar.html
Mirror
http://ul.to/wvsqh7c1
