Android Uygulama Memory & Storage Info Widget v3.1
Gönderim tarihi: 23 / Kasım / 2012 / Cuma - 06:06
Requirements: Android 2.2+
Overview: Memory And Storage Info Widget
This is a simple widget that update itself every 10 seconds. You can place it on your home screen.
It will display:
1. Free Ram.
2. Internal SD Card free space.
3. External SD Card free space.
4. Battery Power Left.
Touch the [Title] for a help popup.
Touch the [Ram Free] for updating the widget.
Touch the [Battery] for the Battery usage window.
Install it and find it in the Widgets. Hold and drag it to your Home Screen.
It takes up to 4 cells, that means one full row of the screen.
1. Added a setting screen to change the colors of the widget.
تم اضافة شاشة الاعدادات لاختيار الالوان حسب رغبتك.
2. Widget background is 50% transparent.
3. You can use the same color for all.
4. The Battery will change to RED if less than 16.
5. Added support for more devices.
6. Some codes was improved for stability.
* Refresh the widget after changing the colors.
It will change the colors on next refresh automatically.
play
Download
http://www.filedownloads.org/4oa89jh...idget.rar.html
Mirror
http://ul.to/y2dppc7z
