Android Uygulama Android Assistant(18 features) (Donate) v4.6
Gönderim tarihi: 22 / Kasım / 2012 / Perşembe - 23:01
Requirements: Android v2.1+
Overview: Top 17 features to help you easily and efficiently manage your android phone.
Top 18 features to help you easily and efficiently manage your android phone.
Android Assistant is one of the most powerful and comprehensive management tools to improve your android phone's performance. It speeds up your phone's running speed and saves battery.
【Top18 features】
1. Monitor status (cpu, memory, battery)
2. Process Manager (Auto Boost and Quick Boost can distinguish different types of processes thus will not kill fatal system processes and apps in Ignore List.)
3. Cache Cleaner
4. System Clean(Browser History, Clipboard, Market History, Gmail History, Google Earth History, Google Map History)
5. Save Battery Settings(bluetooth, wifi, gps, auto-sync, orientation, haptic feedback, screen brightness, timeout)
6. File Manager
7. Startup Manager
8. Batch Uninstall
9. Battery use
10. Volume Control
11. Ringer
12. Startup Time
13. Startup Silent(Menu->Settings->Startup Silent)
14. System Info
15. Widget(Quick Booster[1,4], Shortcuts[4])
16. App 2 SD(Support android2.2 and later):Get more free internal phone storage space
17. Batch Installation
18. App backup and restore
KW: task kill taskkill ATK app killer tool tools taskmanager task manager system panel systempanel process manager processmanager memory taskpanel task panel Advanced Process android 2.3 Android Assistant
Recent changes:
- Fix app backup;
- Fix language setting.
Less description
Latest version: 4.6 (, supports App2SD)
This app has NO advertisement
http://turbobit.net/fyni6ksnmbnm.html
Mirror:
http://ul.to/hea61o0t
http://www.filedownloads.org/06jc7t3xal2u
