Android Uygulama Droid Secret Tips v2.6.0
Gönderim tarihi: 22 / Kasım / 2012 / Perşembe - 18:34
Requirements: Android 1.6+
Overview: Supercharge your Droid with secret tips, tricks, and hacks.
Supercharge your Android phone or tablet with Droid Secret Tips and gain access to tips and secrets about how to use the Droid and other Android devices. Find out how to make your phone run faster, tweak the preferences, and find features you never knew existed. Find new Android apps that fit your needs, and get the most out of the apps you already use.
This "Android how to" resource is packed with knowledge to help you investigate and learn about parts of Android that you never knew existed with secrets and instructions dug up from all over the internet. It's time to master your Droid!
There are already over 100 Android tips in this how-to app, with many more on the way. The database of Droid tips is frequently updated, and the updated tips are downloaded automatically. You can search for something specific, or flip through the tips by experience level.
New features and updates are frequently being released, so be sure to turn on automatic updating or come back to check for updates often.
Most of these tips are for all versions of Android, but a few may not apply to older versions of Android before 2.0. More tips specific to tablets as well as Android 3 and Android 4 (ICS Ice Cream Sandwich) are in the works.
This app and all Android tips are in English and Spanish.
The internet and network permissions are required to download the tips. The phone state permission is required for ads, which support this free version. Any other permission previously required for ads have been removed.
-More tips!
Note: if you have problems updating, be sure you didn't install the app from the Amazon Appstore. If so, you need to uninstall the app and reinstall from this market to be able to update from here.
http://www.filedownloads.org/q678qj9...2.6.0.rar.html
Mirror
http://ul.to/e3mp8hl4
